[SOLVED] Will a cpu fan header work on a 3 pin rgb control hub
Jun 6, 2020
39
Hello guys im in a bit trouble i have a cooler master argb hub and for the rgb to work i need a rgb header which my motherboard doesnt have and their is a cpu fan header which is not used and i was wondering if a pwm connector to 3 pin will solve my problem so the argb will work ill have some picture below
That is a 3 pin ARGB connector their 5 Volt you can't use a fan connector.
What hub do you have?
