will a DVI cable run my monitor at 144hz?
MARK_kakuzo
Commendable
Feb 19, 2016
114
i will but BenQ XL2411Z it doesn't come with a HDMI cable but it comes with DVI cable.
it is 144hz so will the DVI run it with 144hz? or should i order an HDMI with it?
i use a headset connected to the MB not the monitor.
''Specifications''
https://en.wikipedia.org/wiki/Digital_Visual_Interface
my understanding it must be the dual link dvi
Can DVI do 144hz?
To output 1080p content at 144Hz, you typically use a dual link DVI-D cable or DisplayPort cable. You can also use a HDMI 1.3 or higher cable. Running 1080p content at 144Hz can be a very demanding task. Contrary to popular belief, a standard HDMI 1.2 cable can not be used to output 144Hz 1080p content on a monitor.
and my headset is connected to the MB then will i be fine with audio?
''Specifications''
Can DVI do 144hz?
