Will a DVI-D to VGA Active adapter give off the same quality as a VGA to VGA connection?
Shadow777
236
4
18,695
Hello, basically that little question, i have bought a brand new GTX 1060 6gb and it has a Dvi D output and HDMI, and my monitor has only 1 VGA slot, since i know passive adapter dont work it seems like active converters are my only way out, but my question is will someone like me who has always used vga to vga connections notice any degradation in quality? or will the quality be the same as a native Vga to Vga connection?
The quality would be the same whether you use HDMI/DVI-D/Displayport to VGA.
Being an analog signal though, VGA can suffer interference in the signal - and generally monitors supporting only VGA have lesser quality panels vs their Digital counterparts.
That being said though, when using a monitor with only a VGA input, you're going to see exactly the same image/quality whether you run VGA>VGA or Any digital output>VGA (actively converted, of course).
Well. It will degrade the qaulity as DVI and HDMI handle better quality then a VGA would.
However, if you have been using VGA this whole time and you use an adaptor to remain on VGA. That overall VGA quality should be the same that you are already use too.
I would recommend a new monitor in the near future to take advantage of that better quality and possibility higher resolution.
Good, but will there be any noticable input lag / delay because of the conversion? my monitor is 5ms i suppose i wont have any problem if it even goes up to 10ms because of the conversion, but can it be worse than that?
Great!, thats what i wanted to hear i guess
No, there will be absolutely no difference in response time etc - it will be exactly as if you were running VGA>VGA.
MERGED QUESTION
Question from Shadow777 : "DVI to VGA active adapter doubt, need help"
Nobody has any experience with these active adapters?
MERGED QUESTION
Question from Shadow777 : "DVI to VGA active adapter problem, need help"
hey everyone, since i need to buy a dvi to vga active adapter because my video card has only digital outputs and my monitor is VGA i went to amazon searching for an active adapter which is my only salvation, but reading the specificacions of the product y saw it only listed 5 Resolutions, which the one i use isnt among them (1360x760 - 720p) Does this really only support those 5 resolutions or is just my resolution too offstream to even be listed and it does indeed support it?
https://www.amazon.es/UGREEN-Adaptador-Convertidor-monitor-proyector/dp/B01AU804HK
my 1060 only has Dvi-D , hdmi or Displayport, i need an active converter, my question now is the one below
My answer still remains the same. They make the converter as I showed you in the display converts you need. Just google it.
I would avoid using a box adapter, they tend to fail and cause problems. By going with the adapter style I suggested, you dont have to worry about anything failing.
If you want to ignore my advise and go with a box style adapter. Then get the one you linked. It work do just fine until it fails.
oh i see, you seem to not be understanding the problem here haha lol, i have dvi-D which outputs pure digital signal , unlike Dvi-I !!!, so the the plain passive adapter you linked me isnt worth jacksh!t to me because it simply wont work
Dude... I'm saying they make that EXACT adaptor to fit your needs. It is just another style of adaptor design type. Does EXACTLY the same thing.
I'm just saying avoid using the cable attached to the box type adaptors as they tend to fail more often and go with a straight conversion adaptor. Similar to the style of the one I presented earlier.
Just use a standard DVI-D adaptor, not the BOX type adaptors. Again, strictly talking about adaptor design types here.
https://www.amazon.com/Male-DVI-D-Female-VGA-Adapter/dp/B007EA48MA (just google and find the input/outputs you need in this same style)
This type of adaptor has way less going on and is way less likely to fail then those with boxes, such as the one you linked.
is it an active adapter?.. because its not going to simply convert digital signal to analog without a converting chip, btw look at the product reputation, yea no thanks, why does that even exist? D: nice scam
If they made the adaptor... then it has the chip and it will work... that is the whole point of the adaptor. Don't buy it from there I don't care. Find another vendor that has better rating. That was simple an example of the adaptor STYLE. You are not getting the point here. BUY THAT STYLE ADAPTOR is my recommendation.
It exists just like anything else. There are better products out there and there are worse ones. I'm just telling you from experience the ones with boxes only caused issues for me and my clients, I've replaced 5 of them in the last 2 years. However, any with the style that I recommended, I've never had to replace and they been in the field for over 4 years now.
Don't believe me. Buy the one you link and see how long it lasts. That's all I have to say on the subject.
