Will a faster CPU significantly increase virus scan speed?
AntaresX
148
I've been experimenting with the time it takes virus scans to run on various computers in my house. There seems to be little difference with significantly more or less powerful systems. Just to understand how they work, what pieces of hardware would give me faster virus scan speeds? The CPU is the first thing that came to mind.
The place you keep your applications and such on will have the biggest impact so the HDD/SDD, as the read speed of a HDD/SSD will ultimately decide how fast you can get through all your applications. A CPU will increase the speed, no doubt, but as long as the CPU isn't very old or very cheap, then the CPU should be no problem whatsoever.
Hi,
Please read this page before posting on the forum,
http://www.tomshardware.com/forum/19-73-forum-rules-read-first
For your question: It depends on what kind of upgrade. Let's say you upgrade from a pentium 4 1.66ghz to a 3.0 ghz, You will see a difference, but it also depends on the rest of the of the computer, memory and hard drive.
Since most of the virus scan is on the hard drive, the speed of the had drive will have an impact.
If you would of detailed your computer, and what upgrade you will make, we could of told you if it would d of been a a good upgrade or not.
I see, so it's possible to set virus scans to utilize anything they possibly can, and at that point things would most likely be bottlenecked by the HDD.
So the reason all these computers of varying power are taking about the same time to run virus scans is because they all likely have HDDs of the same speed?
