will a geforce 1080 fit and work in my msi nightblade?
Olaf87
Commendable
Oct 13, 2016
I own a MSI nightbblade MI2C-062 (4719072459390) and I was wondering if I could fit a geforce 1080 and if my power supply is enough to properly handle it? (350 watt).
If I can't use/fit that card wich one is the best I could?
At this moment I own a geforce 660 4gb and i'd really like to run games in the ultimate settings (like maffia 3, doom and those kind of demanding games)
you would need to upgrade the psu evga look like they will fit i have a nightblade myself after mesuring my psu i think i can save space slightly instaling the 650w p2 evga however im not 100% sure when this is done then you prob best getting the gpu from amazon so you can send it back if it dosnt fit. However i have a rubbish msi gt 730 gpu in my system which is dual card which the 1080 is and as for the rest it is Height: 4.376in - 111.15mm
Length: 10.5in - 266.7mm my guess is it fits if you can get it past the main power cable to the mobo if you do this let me know as that is my next upgrade as ive just replaced the cpu and ram to max
just to add as of march 2017 i have fitted a 1050ti in my nightblade and with the psu it came with...
just to add as of march 2017 i have fitted a 1050ti in my nightblade and with the psu it came with 350w as mine had a spare 6 pin cable i used Asus strix 1050ti
