[SOLVED] Will A GTX 1050 SC WORK WITH A 265W PSU?
Apr 23, 2020
8
I have a dell optiplex 990 MT
Intel core i5 2400 3.10ghz
8gb ram
265w psu
Im wondering if I could put a gtx 1050 sc in there would it be fine for the psu
it will not be fine the psu is too bad,also if you havent bought the gpu yet go for the 4gb version,cuz its way better than the 2gb one.For you build i would suggest like a cx450.I think the cx 450 is like the GOD when it comes to giving pcs life when buying a mid-range gpu.And trust me,it wont let you down.You can even go with more wattage if u want
CX450:https://www.corsair.com/us/en/Categ...Supply-Units/cx-series-config/p/CP-9020120-NA
