Will a GTX 760 and power upgrade work with a Dell Vostro 270?
imagelover
Hi
I'm trying to work out what reasonably powered graphics card I can put into a very unpowerful DELL office computer! The lower power unit seems like a must to replace, but assuming I can, will a double with full length card fit into the case / motherboard and work?
If not, can anyone offer the best alternative? Ideally NVIDIA Like a 750 Ti? I'm trying to make a small boy a cheapish gaming computer without starting from scratch!
Thanks.
Ben
Depending on the PSU you might be able to get away with out replacing the one you have, I think the GTX 750 Ti only uses like 60w of power and the min system req on Nvidia site is a 300w psu. The gtx 750 Ti is probably your best option... Assuming your budget for this is in the ~$150-$200 range.
Edit: Could you provide a bit more information about the computer? Hard to say what will fit and what won't without knowing the case / specs of the computer.
Hi Derza
Thanks for the feedback.
Here's the machine:
http://www.misco.co.uk/product/213797/Dell-Vostro-270-Desktop-PC-Intel-Core-i3-3240-4GB-1TB-DVDRW-Windows-8-Professional-64-1-Year-Warranty
It says it has a full height PCIe x16 slot but only a 300W power supply.
Even the 750 Ti states 400W for power usage (I presume to sit within a system where other stuff is pulling load)
There just seems a big performance difference between the GTX 760 and GTX 750 and was hoping for a little time before needing to upgrade!
Thanks again for any pointers.
Ben
