Will a hyper TX3 fit in a NZXT Source 210?
Natos
127
I'm building a computer using a NZXT Source 210 for a case. I also plan to use a Cooler Master Hyper TX3 as a CPU cooler. I already have confirmed that it will fit with the RAM I'm planning to use, (no crazy heat spreaders, so it'll work fine) but I'm still a bit concerned about the Hyper TX3 fitting in the Source 210. Would the Hyper TX3 fit in the NZXT Source 210?
Also, if the Hyper TX3 doesn't fit, can you recommend a cooler that will fit and have equal or greater performance to the Hyper TX3?
