A powerline will most likely get you an even connection without spikes vs WiFi. Not as good as buying a spool of Ethernet wire and routing it through the house but I’d use powerline over WiFi.I'm using WiFi. the router is pretty far away too, at the other side of the house
What do you mean im confused, sorryCompared to WiFi or regular Ethernet?
Are you using WiFi atm or are you using a cable plugged in to your PC directly from your router or hub?What do you mean im confused, sorry
I'm using WiFi. the router is pretty far away too, at the other side of the houseAre you using WiFi atm or are you using a cable plugged in to your PC directly from your router or hub?
Alright, thank you so muchA powerline will most likely get you an even connection without spikes vs WiFi. Not as good as buying a spool of Ethernet wire and routing it through the house but I’d use powerline over WiFi.
