A Alex Popa Honorable Aug 18, 2013 8 0 10,510 Aug 20, 2013 #1 I wanna buy a 7770, the only problem is I don't know if it fits with my case. My case looks like this 7770 looks like this Also will it work with this PSU http://www.dc-shop.ro/surse/sursa-sirtec-hpc_400_h12s-l/ ? Thanks in advance
Solution unreal9400 Aug 20, 2013 The HD 7770 will fit in your PC case. The power supply is good too since it has the sufficient power connector (PCI-E 6-pin) for the graphics card.
aatje92 Honorable Mar 31, 2013 2,032 0 12,460 Aug 20, 2013 #2 Sure, it will be behind those metal things. That PSU looks sufficient although i don't know how reliable it is. Anyway it has the right connection. Upvote 0 Downvote
unreal9400 Distinguished Aug 4, 2012 1,913 0 20,460 Aug 20, 2013 Solution #3 The HD 7770 will fit in your PC case. The power supply is good too since it has the sufficient power connector (PCI-E 6-pin) for the graphics card. Upvote 0 Downvote Solution
