I've been going back and forth as to which mATX case I would use for a future PC build, and one of my preferences would be the Inwin 301. It's a flawed case I know, not the best in terms of airflow per se.
But if I do end up with it personally, since its design is to have bottom fans for intake, and the GPU will be very close above them; the cooling of the rest of the components is admittedly concerning since as far as I can see most of the intake will just be stuck at the GPU before it reaches the rest of the case to properly cool, at least if I get a dual-fan one. Whereas getting a single fan GPU will open more space to distribute the cool air to the rest of the components, but the GPU would get warmer since it has less built-in cooling.
In this case for cooling, would using a single fan GPU be just as worth it as a dual-fan one with only minor difference in temps (if anyone has tested this before)? Or sticking with dual fans will still be better for cooling in the long run?
