After doing a bit of research and reading several reviews on Newegg I am wondering if there is an easy way to tell if a particular SSD will work in a particular computer. Like the memory apps that tell you which module to buy.
I have 3 desktop systems. Two will need hard drives in the near future for various reasons. I am thinking of replacing the system drive in my HTPC with a SSD. Although if the price is right I might replace the drives in the other two as well, so I need a fast way to tell if the SSD will work in those systems since I imagine the units will sell out fast.
I don't plan to upgrade to SATA III so I will be looking for a SATA II drive of around 120GB.
When I find a great deal on one (I can wait for Black Friday or longer) is there a way to determine if that particular drive will work in one of my systems?
In some reviews I read that the drive works great in their laptop (something about mSATA) but not in their desktop. Some mention other problems with motherboards, types of controllers, power, etc.
I am not a gamer. I expect the SSD to be $70 or less and already have enough other storage in the HTPC (Of course you can NEVER have enough storage, let's say I have adequate storage for now.) so I'm just looking for a boot drive and a fast startup and no problems once the new drive is installed and configured.
Added questions:
I'll check the forums for an answer but a little more research raises the question of what is the difference between a 2.5" and 3.5" SSD? Does it matter which I choose if I'm going to use it in a desktop? I already have adapters since I'm using old laptop drives in all my systems. (Hence the reason they will need to be replaced they are old (3+ years) and small (70GB). It seems that the 2.5" generally cost less since they are more readily available and popular.
Added questions:
