Question Will a thermalright phantom spirit block ram slots for g.skill trident z5 neo?
Feb 16, 2024
4
I just wanted to make sure this combo would fit. I tried looking it up on pc part picker and it didn’t say if it would fit or not.
Make and model of your motherboard? The benefit of the cooler you've chosen is that you can adjust the height at whicht eh fan closest to the ram slots are mounted.
You will run into clearance issues with your case's side panel though.
To be double sure, please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
need the mother board make
but i can 100% confirm it wont foul my gskil Z5 neo RGB ram on my Asus rog crosshair X670e gene problem i had was it fouling on the gen z m.2 expansion card for extra m.2 drives i couldnt fit a 25mm thick fan had to buy a 15 mm fan for the front ..
yes there is Gskill z5 neo RGB under there !!
