Will a usb 3.0 pcie card work at full speed on a pcie 1.0 slot?
gomilly
315
My motherboard is old and i was thinking i can buy a usb 3.0 pcie card to get faster transfer speeds. My question is will this be an upgrade if my motherboard only supports usb 2.0 or is it going to run usb 3.0 speeds through the pcie slot. I think my pcie is 1.0 version
IMO, adding a USB 3.0 card to an old motherboard only supporting PCI-E 1.0 is not much of an upgrade as it would be limited by the other hardware in the system. Is the PCI-E card you are planning to install an x1? If so, there will be minor improvement as PCI-E 1.0 x1's bandwidth is 250mb/s compared to USB 2.0's 60mb/s.
Yeah its a x1 card. So it probably wouldnt be as fast to usb 3.0 but still a bit faster than 2.0?
