V vodliedood Commendable May 10, 2020 30 1 1,545 Jul 22, 2021 #1 I've got an hd 7950 that doesn't have a VGA port but my monitor only has a single VGA port. Will a DVI-I work or DVI-D will do the trick? I'm confused which one does what
Solution H H hotaru.hino Jul 22, 2021 DVI-I contains the analog signals needed to drive a VGA monitor. DVI-D is digital only.
H hotaru.hino Glorious Sep 1, 2020 9,583 3,492 46,090 Jul 22, 2021 Solution #2 DVI-I contains the analog signals needed to drive a VGA monitor. DVI-D is digital only. Upvote 0 Downvote Solution
vov4ik_il Admirable Mar 23, 2020 1,722 234 7,090 Jul 22, 2021 #3 Second to the above, as long as you have those female pins on the right, it should work. Upvote 0 Downvote
Glenwing Splendid Aug 8, 2015 3,112 322 25,990 Jul 22, 2021 #4 Yes, that's what DVI-I is for. Upvote 0 Downvote
