Will a Zotac GeForce GTX 1080 8GB AMP Extreme graphics card fit into a NZXT Phantom 410 case?
KykiJJ
Commendable
Nov 22, 2016
6
I am looking to buy a Zotac GeForce GTX 1080 8GB AMP Extreme graphics card to put in my NZXT Phantom case. After researching, the case fits graphic cards that are 305mm long without taking out the extra hard drive bay slots. The graphics card is 325mm and I wanted to know if it would work if I took out the extra hard drive bay.
In its default configuration, the NZXT Phantom 410 supports video cards up to 12” (305 mm) long. If you install the optional 120 mm fan on the hard drive cage, this clearance is reduced to 11” (280 mm), but it is increased to 16.5” (420 mm) if the upper hard drive cage is removed from the case.
A Zotac GeForce GTX 1080 8GB AMP Extreme length is 305mm, so there will not be problem to place it, it fits perfectly.
ANSWER IS YES, ITS PEFECTLY FIT IN THIS PC CASE.
Maybe airflow will be problem but if u make coolers in right position it will be awsome.
Kriptonac
73
Faradis
4
i was also thinking for this card but the only thing stopping me is length of the card my case allows me 305 mm clearance for GPU if its really in 305 MM the i am going to buy this card can you pls confirm??
