Will a ZOTAC GTX 1070 AMP! EXTREME fit in my case?
open the case...
the a10 is not good enough for a 1070, wasted money
that 260x is about max you should pair with it
if you want a 1070 then you need a complete system rebuild
Don't worry I completely upgraded the pc it contains an OC i4 4690k etc. I just have the original case left
open the case and measure the space
make sure your power supply has the proper pcie cables for the 1070
