[SOLVED] Will Acer Aspire XC-895 innards fit a standard case? Also, is it a standard PSU?
King Mustard
216
I am considering buying a used Aspire XC-895 (P/N DT.BEWEK.004) but I need more internal 3.5" HDD storage bays.
Do you think the hardware will easily transpose to a standard ATX case, or do think Acer use a custom motherboard etc.?
In addition, do you think it's compatible with a standard ATX PSU?
No it’s not compatible with a standard PSU.
The board uses non- standard 24-pin ATX power connection, and you should check the number of available sata power cable from the included PSU (not speaking about it’s anemic power )
