Will adding a PCIE USB card effect the speed of PCIE Graphics card?
Philip77
Commendable
Sep 21, 2016
5
Not really sure how PCIE works. I have a GTX 1070 on PCIE on my new build. I am running a little shy of USB ports. I want to get a 4 port USB (Includes 1 SATA as well) card. The one I found is PCIE. Will adding this to a free PCIE slot slow down/effect the video card performance? Just wondering since I know if you add an addition video card, it goes from 16x to 8x, but not sure if that is the same logic for addon cards etc. Thanks
what kind of mobo do you have?
2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 3.0/2.0 x16 (max at x4 mode) *1
3 x PCIe 3.0/2.0 x1
1 x PCI
you should be fine. What pcie usb card are you getting?
you will be fine. It wont drop your pcie 16x to 8x
Made a mistake. The one I would need is for the longer pcie slot (Not sure the exact name of that type?) Same size as the video card.
