will amd cpu fan work without braket base
If you mean the retention bracket, yes you need that. But that comes with the motherboard, not the CPU.
I presume by "CPU fan" you are referring to the whole CPU heat sink/fan assembly.
Yes. All AMD MBs come with retention bracket installed.
(The black things on either side of the CPU socket)
cool i thought i might need to buy one
So mobos are possible to NOT come with the retention bracket?
I bought this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131977
, and it doesn't have any form of mounting bracket. The fan I'm using can stock from another computer and the bracket on the other motherboard is very securely held by an adhesive to the under-side of the mobo.
Can I buy a micro ATX fan bracket sold separately?
That motherboard is for Intel processors, not AMD processors. Intel processors use a different cooler mounting arrangement. If you bought an AM3+ cooler as you stated in the beginning, it won't fit that board. Maybe we better back up a bit and start over.
What CPU are you trying to use with that 1150 socket Intel board?
No, no different user. I'm going from a LGA1150 mATX to another LGA1150 mATX board. I actually did find some retention brackets, however they're for 755 models, which are very similar, but not exact. I'm asking if you can refer me to any site that might supply what I need. And yes I'm using an Intel CPU: i7 4770k
@ Zach Manos
Oh, sorry. Didn't notice you hijacked the thread. I thought I was still working with marsden5.
Intel doesn't use retention brackets. AMD uses a retention bracket to mount their cooler to. Intel uses a pushpin mounting that needs no retention bracket. If you are using the stock Intel cooler, it comes with all you need. If you are using a 3rd party cooler, it will come with hdwr. for mounting to whatever socket it is designed for.
All LGA 11xx and 775 socket cooler mounting patterns are the same.
Yea sorry about that haha Thanks, it seems I will need to pick up a 775 then. The plate for the cooler I'm using is attached to the previous board very firmly. Do I need to glue the plate on like the previous board?
I'm not sure what you are referring to. Plate? Glued on? The stock cooler has 4 twist-turn tabs you turn, pull up on, and release to lift off the cooler. If you've done that but can't get the cooler free, it is simply because the thermal paste is holding it to the CPU. Simply twist the cooler a bit back and forth to break the seal.
If we are not on the same page here, maybe you can post a pic of what you are referring to.
How does one post pics to this forum?
OK. That's what I was wondering. Your old PC was an OEM with a goofy proprietary designed cooler and mounting. Your new board is retail and is like most other boards, in so much as it is designed for the stock Intel cooler or an aftermarket cooler of the Intel design.
Apparently you are moving the CPU from the OEM machine to the new machine. Don't bother with the OEM cooler. Either pick up a new/used stock Intel cooler from someplace like ebay, or find an after market cooler for the 1150 socket. Then sell the old board and cooler as a unit. One is no good w/o the other.
The old backplate is either stuck on or like you say they used and adhesive. best not to try to remove it unless you know for sure it has no adhesive on it.
I did all of this to put in a gtx 960...this will probably be the most expensive graphics card I'll ever buy -_- I appreciate it, mate.
