[SOLVED] Will an 1100W PSU for an HP Z800 power my GTX 1080?
Bentley 11211
5
Short Story:
I have a GTX 1080 that crashes my computer (HP Z800) when put under load, presumable because of the PSU (almost 100% sure this is the case because it's instantly as soon as it gets under load—no time to get hot). After some research, my PSU (850W) has a single 18A 12V rail for the graphics card, the 1100W reportedly has 2-18A 12V rails for the graphics card. I'm wondering 1.) Is that true/where can I find technical specs on PSU's? And 2.) If it does have 2-18A 12V rails for the graphics card, would that actually fix the problem and supply enough power to the GTX 1080? Thank you for the help!
Long Story (only if you want the whole sad story):
I've been wanting to upgrade my graphics card for awhile now and due to the recent(-ish) price drop on the GTX 1080's I splurged and got one, thinking that my Z800's 850W PSU was more than enough to handle it and not taking a second thought.
When the card arrived I put it in the machine and realized that my Z800 only had 6-pin connectors, not the required 8-pin connectors. After researching online it seemed (almost) unanimous that a 6-to-8 pin adapter would do the trick, so I ordered a couple, hooked it up and it worked like a charm. I booted the machine, installed the drivers, and went to test it out on Steam's VR Benchmark Test to see how it was doing. The client started up and after about half a second my PC crashed. No blue screen—just a horrifying click, a black screen, and then after about 5 seconds it rebooted itself as if nothing had happened.
I don't know much about PSU's, but I knew enough to know that it was a PSU problem, and after some research it seems like the issue is that the Z800's 850W PSU only has a single 18A 12V rail for the graphics card which isn't enough power for the GTX 1080 (it says it needs 225W, which is what HP claims the 850W should do, but somewhere in practice it's not working out). I found a single person claiming that the 1100W PSU would fix the issue as it has 2-18A 12V rails to the graphics card. Again, I don't know much about PSU's, so I don't know if what they are saying is reliable or even makes sense, but it seems reasonable to me? I just wanted to get a second opinion from some more experienced PC builders to see if the 1100W PSU would fix the issue or just be a waste of a few hundred dollars. Thanks for the advice!
I don't think it has to do with wattage but how the power is delivered to the board.
If HP is using slide-in server PSUs and since the power cable are not connected to the PSU, then it might not deliver enough power to the GPU and that is why they only include 6-pin power cables.
Take in consideration that the components for that system are 9 years old and even if you get a 1100W PSU it might be 9-year old unit that was not meant to power a GTX 1080.
If the 1110W model is HP 480794-004 then it supposed to have 6x 18A 12V rails... 2x mobo, 2x CPU and 2x GPU.
Yep the 850W has only a single 18A rail for GPU. Did you take a look at the label on the one you have?
Do you have the models of the 1100W and 1250W PSUs?
How many 6-pin PCIe...
Sorry, I forgot to mention that the Z800 has specialized parts, so I can't use any PSU. My options are HP's 850W, 1100W, and 1250W. I know that they are all overkill, but they're my only options unless I want to shell out the money for a new case, PSU, and most likely motherboard because as far as I know the mounts in the Z800 mobo don't line up with any sort of standard case.
How many 6-pin PCIe power cables do the system has?
I went ahead and bought the 1100W PSU with a decent return policy and it didn't fix the issue. I bought a new motherboard and installed a standard 750W PSU and it works, so it wasn't anything wrong with the card. Looks like the Z800 is just too old for a GTX 1080 unfortunately. Thanks for the help guys
Friends I am using ho z800 PC my default PSU damage I bought new PSU Thermaltake 1000w through power and I buy main power cable 18 pin connector in Ali Express and I attached PSU and start the pc but showing 4 time beep and not start pc but I removed my hdd PC working perfect.i don't know what happened this issue plz help me.i attached hdd in PC always showing 4 time beep.and removed hdd working perfectly.plz solve this
1562307527344282059415-jpg.8036
15623076393101791000179-jpg.8037
