[SOLVED] Will Arctic Freezer 34 eSports fit
Feb 4, 2020
18
Hi!
I want to buy Arctic Freezer 34 eSports cooler, because with stock cooler for ryzen 5 2600 I get high temperature. I have MSI Tomahawk b450 max motherboard and Corsair Vengeance rgb pro RAM. Will this cooler fit?
Chassis Corsair Midi Tower Carbide 200R. Temperatures for CPU are idle 45-48 C, gaming 70-72 C. Room temperature is 23 C. I dont know yet abou overclock, but probably I will do it in future.
The Carbide 200R can accommodate a cooler with a height of 165mm max, while the freezer 34 is only 157mm high. It will fit for sure considering it's a pretty slim CPU cooler.
We're going to need more information. What is the make and model of your chassis? SO as to avoid clearance issues after installation. Then we're also going to need the temps for your processor+your ambient room temps. As well as if you're performing an overclock to see if you can avoid spending the additional money since the ambient air temps will dictate what sort of temps you get eventually, regardless of what cooler you pick out.
