[SOLVED] will arctic freezer ii 280mm fit into a fractal design meshify 2 top ?
Mar 8, 2022
Im building a new system . and wondered if the arctic freezer ii 280mm fit into a fractal design meshify 2 top (or would a 5000d airflow make a better option)?
the mobo will be either: msi z690 pro A ddr4 or z690 tomahawk wifi ddr4.
thanks alot
thanks alot
The Meshify 2 supports radiators up to 360/420mm (3x 120mm or 3x 140mm) in size. That means that it will be able to fit a 280mm AIO.
thanks alot
thanks for the reply , does that mean that in terms of the arctic freezer ii 280mm thickness there will be enough clearance for the ram in the build that i mentioned ?
Latest posts
