[SOLVED] Will b450 or x470 mobos work out of box with 3000 series ryzen cpus?
Jul 7, 2019
will b450 or x470 mobos work out of box with 3000 series ryzen?
I will be upgrading this summer and I need to know beforehand in order to feel comfortable buying.
Will I be able to upgrade the bios while using the new processor or do I have to download the bios update on a flash drive or something like that?
You will need a natively compatible processor (second generation) in order to upgrade the BIOS to allow for third generation processors. If you do not have one, a local PC Shop (or if you're purchasing the motherboard locally) may be able to do it for you.
-Wolf sends
