Will BitFenix ALCHEMY individually sleeved cables work with my Seasonic PSU
Off your amazon product link:
Compatibility: KM3 Series: X-850 KM3, X-750 KM3, X-650 KM3; XM2 Series: 1250W XM2, 1050W XM2.
No! It's not compatible and trying to experiment with the cable kit may damage more than just the PSU. If you're interested in buying an individually sleeved cable kit, you're best served by going with MODDiy, Ensoruced or Cable-Mod.
FYI, the PSU you're eyeing is an SS-XP2 series.
Yes it won't work.
But the Seasonic Snow Silent 750w is actually under the XP3 bracket (not XP2)
CableMod definitely has compatibility with it - SE Series.
Or you could just get cable extensions, So that way any brand will work with it...
Only problem is you will still have the black wires coming out of the power supply end,
but the red wires going to the motherboard.
I prefer the colored connectors on the bitfenix alchemy extension range.
If you wanted red cables then you also get the red connector instead of black.
They are an older range now. Not too much stock left
