Will Chieftec ATX-410-212 handle ATI Radeon X1950pro ?
sebastian_
37
Hi, I have an old Chieftec ATX-410-212 PSU
It's old but - it was never used actually - it was just laying on shelf all this time.
When it comes to 12v line it looks like this :
+12V1 15A
+12V2 18A
- max load for 12v line - it says 240W
Will it be able to power ATI Radeon x1950pro and 3ghz CPU ?
Thanks.
My mistake. I looked up the wrong part. Since you have the PCIe cable you can try it. It's a bit low on power but may work. 300 watts or higher is recommended for the card. If you experience random shutdowns you'll have to upgrade the power supply.
Thanks for respond,
hmm... well... but this chieftec has 6-pin PCIe power cable...
