Question will cities skylines run better with overclocking?
dramacydal
51
I got asus b350 motherboard, light comes on but desktop will not power up. this happened twice today and Friday, after 30-40 mins tried my luck and then powered up. Also weirdly even my time zone is wrong.
I got asus b350 motherboard ( wifi one ) and corsair 16x1 3000mz ram. i wanna add 8gb more ram ( for a game, cities skylines ) can i 8gb or has to be 16? Also does it have to be 3000mz or can be 2400. sale at local hardware store 2400mz are running at 50% while 3000mz only 10% off.
will cities skylines ( game ) run better with overclocking?
currently with mods loaded it gets very laggy after decently big city.
this is my pc, always had a gaming laptop.
my rig-
1060 gtx 8 or 6gb not sure
16gb x 1 ram 3000mz
ryzen 1700x
asus b350
sandisk 1tb ssd
power supply i dont remember exactly but i think tx 650 or 750
"better", very likely yes... assuming the OC is stable.
Whether "better" is great performance, or only marginally less bad in performance, depends on what you're trying to accomplish.
A GTX 1060 is 3GB or 6GB, there is no 8.
If you're only running 1x16GB, you're hindering that CPU. Ryzen really benefits from dual-channel memory....
hey u merged my threads. rest is fine but the power on issue is very important
what is oc? then 6gb 1060gb
oh i wish i knew it earlier, now got 16gb one so whats the solution. i want significant improvement not marginally less bad. game is using 60% ram and 40% gpu.
