_Synoflux_ :
Franklin_4 :
honestly, get this instead...
Deepcool GAMMAX 400.
It comes AM3+ and AM4 ready, so you wont need to buy a seperate adapter. It also has brackets for intel sockets. Its about the same cost as the hyper212evo, it has similar cooling capabilities, and its gotta cool blue LED fan attached. Also, you should be equally concerned about the clearance in your case. Both these coolers are just under 160mm tall, and a lot of cases will be too small to house them. what case ru using?
Hi thank you all for quick replies.
I am using the CiT Vantage case and I have been browsing for a good sized budget case for a while now but cannot seem to find one. My current case is 18.4cm wide and I do not believe you can fit either a cooler master hyper or gammax in but I'm not too sure. The reason I am buying a new cooler is because I am using the stock cooler on my FX 8350 and it sounds like a jet engine when I'm playing games.
The Gammax sounds good as it is AM4 and AM3+ ready so I would like to get that. I'm not set on either cooler I am just trying to find a decent cooler that is relatively quiet and high performance.
https://www.cclonline.com/product/55382/8818B/Cases/CiT-Vantage-Gaming-Case/CAS0231/
https://www.cclonline.com/product/76317/8818R/Cases/Vantage-Type-R-Gaming-Case/CAS0547/
https://www.cclonline.com/product/113601/8818G/Cases/CiT-Vantage-Green-Midi-Mesh-Gaming-Case-Black-Interior-4-Fans-3-Green-LED-Card-Reader-No-PSU/CAS0839/
Clearances
Max GPU Length: 375mm
Max CPU Cooler Height: 160mm
Physical
Form Factor Mid Tower Case
Case Colour Black
Motherboard Compatibility ATX • mATX • ITX
Width 206 mm, 204mm, 204mm
Depth 468 mm, 467 mm, 467 mm
Height 447 mm, 448 mm, 448 mm
Weight 5.2 kg, 5.4 kg, 5.4 kg
Item Details
Manufacturer CiT
Part Number 8818B, 8818R, 8818G
EAN 8026881182002, 5055492411419, 5055492411822
(This covers all three cases I found of that model of case.)
According to this info (please make sure it it matches your case) the EVO would just barely fit. The Gammaxx 400 would have a little more room, and (if you can get it where you live,) a Cryorig H7 would have even more room. The Scythe - Kotetsu would be the tallest, at max height - 160mm.
As a side note: save up some cash and replace the power supply that came with that case with a better unit, if it came with one. Typically ones included with that size of case are complete rubbish that will eventually, if not sooner, damage your expensive parts when they die, if not before.
