Question Will Cooler master TD500 mesh case fit 280mm aio on the top?
vlad0934
14
my aio is Corsair h115i Pro which has 2 140mm fans, the case say is it supports 2 140mm fans on the top part but doesn’t list the 280mm radiator. This is just confusing me as u can fit a 360mm radiator but not a 280mm one?
can someone please help me out I’ve been looking all over the internet and literally nobody answers this question they just kind of avoid talking about it, my current case gets very hot as The 3080 puts out a lot of heat and the TD500 case is literally the best one I could find that isn’t very expensive, fits a 325mm gpu, and has a top mounted radiator spot allowing for some good airflow.
if the 280mm radiator can’t fit at the top what case could u suggest that would do The job (gotta be good looking and come in white color as my entirety build theme is white, and most importantly have a radiator mount at the top with 3 or so fans in the front because the 3080 puts out too much heat for me to use up the front mount for aio.
Which of the two is it?
https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-td500/#specifications
RADIATOR SUPPORT - FRONT 120mm, 140mm, 240mm, 280mm, 360mm
RADIATOR SUPPORT - TOP 120mm, 240mm
RADIATOR SUPPORT - REAR120mm
https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-td500-mesh-mesh-white/#specifications
RADIATOR SUPPORT - TOP 120mm, 240mm, 360mm, (44mm max motherboard component height)
RADIATOR SUPPORT - REAR 120mm
second one, the mesh one
