Aryend :
kvragec :
MeteorsRaining :
I've no issues with your arguement, and I'll be happy to justify my response, what I am not fit with is the abuse you hurled.
Anyways, my justification:
HD 7870 is a 175W card and 970 is 145W, so there are no issues with replacing the cards as that won't give any extra load to PSU.
Now to OCing. The fact that you're missing is that PSU quality (not wattage) solely determines the regulation of voltage given to CPU. OCing will require more Voltage draw and so PSU needs to give out more Voltage, and more importantly, give it out continously. That is why quality is important. Low quality caps used in CX have been observed to fail to provide continous and regulated voltage. And lack of correct and continous power will result in instability. It's as simple as that.
http://www.techpowerup.com/reviews/ASUS/GTX_970_STRIX_OC/23.html
AMD 7870 uses less energy then gtx 970...
On a tomshardware article about them they stated that this cards can pull even up to 300 w occasionally in a short moments... Maxwell is great but no gtx 970 uses less energy then 7870 or my R9 270x. And i am planning to buy one so just to be fair. If you want to i can paste link from tomshardware article but i think you can find it yourself.
thanks, from what I'm seeing here seems like the difference is not that much though, I see that the max consumption of the 7870 is at 166w and the max of the 970 is at 173w, so the difference seems neglible, although the average seems quite a bit higher.
No problem... On average is around 50 watts and considering performance that is negligeble... But if you thinking about overclocking you'll have to buy something around 650 watts, and if you consider SLI no less than 850 watts... That is my honest advice and anyone could arque with me if they think i'm wrong. And to note something, Gigabyte 970 gaming g1 on many review sites pull same or even more energy then reference 980 just for info... And i think that MSI version is somewhere around that or little lower, all other cards pull something like Asus strix.
And here is something interesting for you to read
... So you can easily see how much power oveclocked fx 6300 needs...
http://www.techspot.com/article/932-amd-fx-8350-fx-6300-power-performance/
My recomendation for PSU: XFX XTR 550 W if you will not overclock gpu but cpu only... that should be enough
XFX XTR 650 W if you overclock both.
I listed that psus cause are available i croatia and are great, other members could list more. For sli you can take something of the same quality but with 850 watts...
