Will Corsair PSU work with non-sinwave (square wave) UPS ?
Tom_100
74
Hello,
I have a UPS, the official specification of which is listed here -
http://www.intextechnologies.com/webpages/productcomperi.aspx?category=Computer%20Peripherals&subcat=UPS&subcat1=600%20VA&pro_name=PROTECTOR%20725
My UPS under battery mode outputs square wave waveform as stated in the official specification.
I am plaaning to buy CORSAIR PSU either one of these -
http://www.flipkart.com/corsair-cmpsu-430cxv2uk-430-watts-psu/p/itmd5xz5qs9mhqmq?pid=PSUD5XZ4ZJ5YPGBU&affid=adminfindp
or
http://www.flipkart.com/corsair-vs450-450-watts-psu/p/itmdbfa3kaffmum3?pid=PSUDBF9ZBHSJVGJ8&affid=adminfindp
My current rig is as follows -
Motherboard - Intel DH61WW
Processor - i3-2100 3.10 MHZ
RAM - 2 X 4 GB DDR3
Video Card - Sapphire ATI RADEON HD 7750 1GB DDR5
Hard Disk - 1 TB SATA Western Digital
Removable Drives - 1 DVD Writer
My question is will any of those corsair PSU model work without any hassle, considering my UPS outputs square wave waveform under battery mode ?
If not, then what will be suitable for me ? Please advice.
fil1p
944
123
Hey,
I just wanted to say that I am running a corsair tx750 (not the v2), and it is made by CWT. As ko888 said, psu's made by CWT should have no problem running on a non sinewave ups. I use my corsair tx750 along with a APC smart ups sc1500va, and so far I have not had any issues. From what I read my ups is not pure sinewave, and It has worked well (its a rack-mountable server grade ups). So it should work if the OEM is CWT, I am not sure about the corsair psu's whose OEM is Seasonic, but they're a great brand and from what I have read these should work without any issues as well. I have used different ups on different machines and have not experienced any issues, even with generic psu's. Most power supplies and ups's are designed to work with each other, otherwise what would be the point of getting a ups.
Hope this helped a bit!
Tom_100
74
@rolli59: So do you think any of those above mentioned CORSAIR PSUs (with Active PFC ) will not shut down when the UPS supplies non sine wave waveform under battery mode ? Please confirm.
Which one of the models do you suggest to be better
Quaddro
Actually APFC circuits in any PSU are susceptible to non-sine wave that generated by backup UPS..
If you use it for a long time, it will damage your PSU apfc circuit,
in other word,
will damage your PSU... :)
But, will it work..?
Yes..
but don't use it for a long time (more than 5 minutes)..
Main purpose of backup UPS just to give you time to save your work and shut down the computer...
Tom_100
74
@Quaddro: I use the UPS backup facility not for working but for shutting down the pc properly during power outage - which does not take me more than 5 minutes.
Today my Chinese make 500 W PSU's fan stopped rotating.
So I am thinking of buying Corsair CX 430. But my question is in my locality the voltage of the power ( that I get from wall's socket ) sometime goes down very low for few seconds and then my UPS goes into backup mode and I can hear a sudden Windows 7 buzz sound in my speakers and mouse gets stuck for 1 or 2 seconds and then everything comes becomes normal. So wondering if my UPS killed my 1 year old PSU's fan and if Corsair will get killed too by this non-sine wave UPS of mine.
@rolli59: Is there a Corsair CX 430 version 2 ? Does it differ from the one shown in the above links ?
Here is the other version I belief very similar http://www.corsair.com/en/power-supply-units/cx-series-psu/cx430-80-plus-bronze-certified-power-supply.html
Quaddro
Okay,
Quick and dirty analysis..:D
what is kill your psu is not your ups..
But your Primary Power Source (electricity from the wall)..
this is what we called Voltage Brownout / Sag
This voltage drop can be up to half of what it should be, and time is only a mili second.
Brownout is more likely to cause problems than Blackout (electricity shutdown).
Cheap UPS can not necessarily overcome this brown out problem..
why...?
when brown ouut happening, the switch inside ups still in the power source mode, not in battery mode..that's means your ups still delivers bad quality electrical power from the wall, not from battery..
and and it's damaging your psu...
So how to solve this problem...?
Just put a (good) power stabilizer between your ups and your psu...
it will stabilize your ups output, and make sure that your psu receive the appropriate voltage..
simple diagram (sorry, i'm not good in drawing :D )
AFAIK, many Seasonic-built APFC PSUs will actually work on a stepped square wave. It is the Delta-built Antecs (and some others) like my SG-650 that REQUIRE sine-wave power, or they shut down, sensing bad input power.
The ORIGINAL Corsair Builder was made by Seasonic. If that's the one you can get, it's a decent choice. The V2 version, however, is made by CWT using Samxon capacitors from an inferior line known to experience early failure. They test well, but won't hold up. I can provide links to support this assertion if desired. In any case, I would not buy one, so I can't ethically recommend anyone else buy it.
Edit: Incidentally, most "budget" UPS units from reputable sources (e.g. APC, Tripplite) will switch to battery if the input voltage drops below ~88-92 VAC (presumably twice that on 230V models); so they DO offer some brownout protection.
Tom_100
74
Hmmm ........ so there is is this new thing that I must take into account now - "The brown out problem". I thought any UPS has got stabilization circuit as well.
I had the notion that when the wall socket voltage drops below workable level for few seconds - the UPS circuit will automatically switch to battery mode detecting the voltage drop.
So Seasonic models will be a better choice for a UPS that outputs stepped square wave during battery mode ?
"Just put a (good) power stabilizer between your ups and your psu...
it will stabilize your ups output, and make sure that your psu receive the appropriate voltage.. "
What models do you suggest for voltage stabilizer to be fitted in between the UPS and the PC's PSU ? Will the stabilizer convert the square wave outputted by the UPS during voltage drop or power failure to normal Sine wave ?
Quaddro
Yes.
but during brownout, voltage up and down very fast..
for example in 220v wall output
lowest lever for an ups to work in battery mode is 170v
during brown out, voltage from the wall actually up and down with very fast, say it around 130v-180v..
it's give no chance to switch to decide if it work in power source mode or battery mode..
Stabilizer function in the cheap backup ups actually just make output worse..
Any stabilizer equipped with get ( constant voltage transformer ) or servo stabilizer from any good manufacturer will do this job..
no, stabilizer is designed to automatically maintain a constant voltage level..but not to convert your square wave to the sine wave.
Tom_100
74
Is there any chance of the stabilizer getting damaged by the square wave output from the UPS during battery mode ? Secondly my UPS can officially handle 360 Watt. So my question is how much will the stabilizer consume ? I have already got a 21.5 inch LED Philips monitor and the 500 Watt PSU ( of my PC ) attached to the UPS. Will the UPS be able to withstand all the load ?
If you can recommend brands and model names and related web page links it would be help ful for me to find a suitable one in the local market. Is there anything that I should check in the stabilizer specification to be sure it will work smoothly with PC ? I have seen people using stabilizers for refrigerators but do not know whether those models will work
with PC.
Quaddro
Yes..but it takes long time to damage it..so don't worry..:)
Stabilizer, like apfc psu, designed to work with pure sinewave..
[/quotemsg]
according to your information, your system consume roughly 250-275 watt in full load..
+ 20-30 watt monitor..
total 270-300 watt..
actually, yes, it will work..(but just for save your work and shutdown your computer)
APC LE600I is an example for a good stabilizer..
http://www.newegg.com/Product/Product.aspx?Item=N82E16812106066
Quaddro
yes, ppfc psu is less vulnerable to square sinewave than apfc..
why?
non pfc psu arena does not have a regular monitoring found on psu APFC.
In this case pfc monitoring IC is the most influential in order to detecting the input signals if it is pure sine wave, step sine wave or simulated sine wave..
but, since you using your computer less than 2 minutes in order to save your work and shutdown your computer, it will no effect even if you using apfc psu..
Okay..if you insist to use ppfc psu..
Btw
what is iBall sprinter..?
i never heard that psu brand..
Dont ever use unknow brand psu, most of it has fake wattage label, unstable rail stability and horrible ripple..
There are many good ppfc psu, such
as acbell 420/470,
Rosewill RP500-2 500W (http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=32),
and many others..
Stabilizers are usually over 95% efficient so you should be able to get 340 Watts to your attached devices.
http://www.ebay.in/itm/270883992879
Most decent UPS units, such as APC, once switched to battery, will remain on battery until the input voltage has stabilized. I believe a five-second period is common. The rapid swings that can occur during a power problem thus won't make it through to your PC.
AFAIK, "iBall" is not a quality PSU.
Tom_100
74
"what is iBall sprinter..?
i never heard that psu brand.. "
Here is listing - http://www.homeshop18.com/iball-sprinter-genuine-450-watts-power-supply-version-2-0/computer-peripherals/others/product:28848635/cid:3334/
Here is the main company website - www.iball.co.in
@ko888 and @Onus - thank you for your advice and suggestion.
@Quaddro: If I buy CorsAir CX 430 or VS 450 or Cooler Master Thunder 450 which all have got Active PFC circuits will they shut down my PC when they detect square waveform output from my UPS under battery mode during power outage ? If that is true then it will not be fruitful for me because improper shut-down of machine will hurt my hard disk badly and will result in a hard disk crash if it happens all the time and I will loose all my data. That is why I was thinking of going for iBall Sprinter 450 which does not have Active PFC circuits.
Please confirm.
Tom_100
74
Please confirm.
The iBall unit looks to be a PSU-shaped object; I would not trust it to reliably power a computer system. It may not shut off on a UPS waveform, but could damage your PSU for other reasons, like out-of-spec ripple and noise, turn-on spikes, or catastrophic failure for no apparent reason. Since filters are one of the things omitted in cheap PSUs, the line variations you have been describing could easily be the cause of such a failure.
I do not know how the Corsair units would respond to a stepped square wave. You may have to buy one, test it, and return it immediately if it does not work.
Quaddro
i'm not recommended this iball psu..
Unknown oem, also no professional review at all..
take a seasonic based psu..
this psu brand known for their reliability and also can handle stepped stepped sinewave.
SeaSonic S12 II SS-430GB 430W is good choice..
but if you insist to use non apfc or passive pfc psu,
acbell 420/470 or Rosewill RP500-2 500W are good choices..
but beware about low effeciency..
