Will G.SKILL Ripjaws 4 Series work with Amd Ryzen?
Matt_matrix
74
I was able to snag A used 16GB (2-8Gb) kit of G.SKILL Ripjaws 4 Series DDR4 SDRAM 3000 Memory F4-3000C15D-16GRBB For $80 USD, Will This ram Work With a R7 1700 And An Asrock X370 Taichi in Dual channel mode?
Will they work with This set up? I know Ripjaws 4 is similar to Ripjaws V and Ripjaws V 3000mhz Is confirmed by Asrock as compatible with The x370 Taichi but at a lower speed with different timings.
im still well within the return period so i could try to return These Sticks, and put $60 with my
$80 refund and buy some ram I know will work with the Asrock X370 Taichi. Should i go ahead and do that?
Thanks. You've slain my worry's about finally building a New rig and having it not even post because of the ram.
