Will GIGABYTE GTX 970 WF G1 fit my case?
bimbaws
357
Hi I want to ask.. I'm little confused if this card will fit my case, because on my Mobo is right next to PCI-E slot also USB 3.0 connector from case. Specs are below (copied from elsewhere)
CPU i5-6600K
GPU Gigabyte GTX 970 WF G1
MB MSI B150 PC Mate ATX
RAM ADATA 2 x 8GB DDR4 2133Mhz CL15
HDD/SSD 1TB + 500GB Samsung + 320GB WD + 320GB Seagate / 120GB Kingston
PSU CoolerMaster Thunder 600W PFC Active ATX
Case Zalman Z3 Plus White ATX
Should be fine, Case supports up to 360mm GPU. And that USB 3.0 connector shouldn't be in the way. Check out the pic on the website of the case. http://www.zalman.com/global/product/Product_Read.php?Idx=821
Okay, thanks! I'll select this as solution, but first I want to ask.. it requires power through 6 and 8pin... now my PSU has only 1 6+2pin, but I saw that I earn Molex to 6pin to the GPU... Problem is that the Molex has only 3pins, and my PSU where it should be connected has 4pins. Now is it compatible?
1 more quick thing, do you already have this system or are you going to purchase it?
Because in your specs you've already stated that you have a MSI 970.
And 1 more thing, a B150 board wouldnt be much use for a 6600k as the processor is overclockable but the board isnt a overclocking board.
Well because I dont have 2 x PCI-E connectors, if I buy the GIGABYTE 970 I'll earn extra cable - Molex to PCI-E.. but from picture I saw that it is Molex 3pin..
ImgW.ashx
But you see, these are only 3pin molex. And my PSU has 4pin. Will it work together?
Thanks dude! I just want to make sure it will work fine
yes it will still turbo to 3.9ghz. But cant be manually overclocker higher
