Will GPU and wireless card fit on my motherboard?
Husky_Musky
Commendable
Jun 25, 2016
25
I was wondering if the GPU and the wireless card will fit on the motherboard, thanks in advance
Motherboard - Asus M4N68T-M Micro ATX AM3 Motherboard
GPU - MSI TWIN FROZR GAMING GEFORCE GTX 780
Wireless card - TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
No he can find a PCI wifi card or a USB solution, the PCI is usually cheaper and has less driver issues (in my experience)...
depends on the wireless card
you have two PCI slots and a pcie x1 slot that may be blocked by that gpu
Yeah i forgot to mention the wireless card (TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter)
Do you have any tips on this problem?
Yes, you would need to find a wireless card that fits into the PCI type slot, That is the one of the 2 long slots next to the really short one. When looking for the card make sure it is PCI not PCIe. The reason is that the GPU will cover the really short slot when installed so you can't use it, the GPU cannot go into any other slot by the way. If you can't find a PCI wireless card then you can always get an external wifi card (uses USB).
Nope that won't fit sorry.
you are going to need a wired or usb solution, the only pcie x1 slot you have will be blocked by your video card
http://www.tp-link.com.au/products/details/TL-WN851ND.html
This will fit your board
The cheapest option for you would actually be to use this
http://www.ebay.com.au/itm/like/121955595033?lpid=107&chn=ps
This will allow you to mount the card onto the case where the card has room.
sure enough... they still make PCI wifi cards XD
