Will GTS 450 work on my PC
rickrishav
5
I have a DG31PR Motherboard with 3 GB RAM
and
Intel Core 2 CPU E7500 @ 2.93GHz (2 CPUs)
http://i.min.us/il4Yfq.png
Will GTS 450 give me good performance? Will games run smoothly on a resolution of maybe 1600*1024?
If not which graphic card should i go for?
Thanks
celpas
778
yes you will be able to max out most games at that resolution.You may have to lower some settings in hyper demanding games like crysis,metro 2033.
dagasaitim
215
Definitely Yes i have that GTS 450 it give me good performance im happy with this card
Before my gpu is 8400SE then i upgrade it to GTS 450 it gives me HUGE PERFORMANCE BOOST I can MAX MOST OF GAMES WITH NO LAGG your pc is quite fast than mine.
my pc
Dual core e5200 2.5hz
ddr2 2gb
GTS 450
IM HAPPY WITH IT!
GO FOR GTS 450!
