A avtechq07 Honorable May 10, 2013 40 0 10,530 Apr 4, 2015 #1 the minimum requirements specify a gtx 660,does the minimum requirement specify for 1080p gameplay at low settings or to run the game at all.Will the gtx 750 ti be able to run the game even @1024*768 resolution..
Solution bimbaws Apr 4, 2015 GTX 750Ti is better than 660 so yes. I hope that 750Ti could handle Witcher 3 on Medium-High Settings. But that also depends on other parts of config
bimbaws Honorable Dec 1, 2013 357 0 10,860 Apr 4, 2015 Solution #2 GTX 750Ti is better than 660 so yes. I hope that 750Ti could handle Witcher 3 on Medium-High Settings. But that also depends on other parts of config Upvote 0 Downvote Solution
Undying89 Distinguished Mar 16, 2008 1,929 0 20,460 Apr 4, 2015 #3 Yes, 750ti is very capable and it will able to run it. Do not worry about it. Upvote 0 Downvote
A avtechq07 Honorable May 10, 2013 40 0 10,530 Apr 5, 2015 #4 what about @1366*768 or 1280*720 at low settings Upvote 0 Downvote
A avtechq07 Honorable May 10, 2013 40 0 10,530 Apr 13, 2015 #5 NicolaasGeelhoed : What's your monitors max resolution? 1366*768 Upvote 0 Downvote
