N Newbie-asker Reputable Oct 13, 2015 327 0 4,790 Dec 31, 2015 #1 Hello, Is this power supply enough for GTX 750 TI? [Photo Below] Thankfully!
Solution C C chrisb99 Jan 3, 2016 Its not enough it could end up killing Your system or in the worst case start a fire
C chrisb99 Reputable May 13, 2014 360 0 4,860 Dec 31, 2015 #2 i would not use that psu at all Upvote 0 Downvote
N Newbie-asker Reputable Oct 13, 2015 327 0 4,790 Dec 31, 2015 #3 chrisb99 : i would not use that psu at all What? Specs is: Core i3 4th gen and 4 gig ram Upvote 0 Downvote
C chrisb99 Reputable May 13, 2014 360 0 4,860 Jan 1, 2016 #4 It does not give enough watts and i am not sure if it the 12volt rail can give enough Power and oem Power supplys are generally low quality Upvote 0 Downvote
N Newbie-asker Reputable Oct 13, 2015 327 0 4,790 Jan 1, 2016 #5 chrisb99 : It does not give enough watts and i am not sure if it the 12volt rail can give enough Power and oem Power supplys are generally low quality So it won't be enough right? Upvote 0 Downvote
C chrisb99 Reputable May 13, 2014 360 0 4,860 Jan 3, 2016 Solution #6 Its not enough it could end up killing Your system or in the worst case start a fire Upvote 0 Downvote Solution
N Newbie-asker Reputable Oct 13, 2015 327 0 4,790 Jan 3, 2016 #7 chrisb99 : Its not enough it could end up killing Your system or in the worst case start a fire Woah! I'm gonna buy gaming laptop which is portable much better! Thanks! Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,615 1,779 159,590 Jan 3, 2016 #8 A 750ti would probably run off of it , if it was a 750ti that didn't require additional power. Upvote 0 Downvote
N Newbie-asker Reputable Oct 13, 2015 327 0 4,790 Jan 4, 2016 #9 A 750ti would probably run off of it , if it was a 750ti that didn't require additional power. Low profile? Please send a link of the GPU you said on Amazon thank you Upvote 0 Downvote
