Will i be able to max out all games 2012-2016?
Denis Stoikovski
2,200
So can i max out games like ac4 watch dogs crysis3 far cry 3 and far cry 4 ofc with i5 3350p palit 770 8 ram 1600mhz on 1440x900 res? also i will lower the shadows as much as i can but i want to keep the aa to a higher level.
Yeah but i watched so many vuds with 770 evga asus palit and they had like 25-58 fps on ultra without even txaa 4x with i7 4th gen and 16 ram corsair vengeance so i dont want to screw myself with the gpu i already did it with one laptop and this pc but those guys res wa 1080p so.. but still i though the 770 can max out games on 1080p
Could you link videos where GTX-770 gives low FPS on games without AA? I have even lower GPU (GTX-760) and I can play almost all games with 50~60+ FPS on ultra without AA.
Didn't play Titanfall, Arma3 all Batmans yet.
i5-4670k.
2x4GB 1866MHz CL9.
MSI GTX-760 2GB Twin Frozr.
You have to be able to run almost all games on 60+ FPS with ultra setting at 1080p that's for sure
http://www.youtube.com/watch?v=sIYlbnEcdgI that one is with txaa 4x ok but no matter 770 suports it 25 fps..
Well, The video is old and nVidia has optimized drivers for many games, If you want to play AC4 in 1440x900 you'll get 60+ FPS if you disable AA, I have played now with all maxed out and I get around 25~60FPS on 1080p monitor.
no aa? even fxaa? i though i would be able to make it to at least msaa 4x
I didn't understand.. and i feel dumb so i should forget about gaming if the 770 can't run msaa 4x or i should forget bout gaming casue the 770 won't handle 4x msaa
Dude, chill out. The 770 is one of the best top notch gpus u can buy. I have a gt 740m and let me tell you it sucks. But i can play most games low-medium. I was able to play crysis 3 on medium settings. If you buy a 770 thatll lat minimum 3-4 years on high, and then medium for the next two. Just buy the damn card.
Thanks for the encouragement 😀 no one said that before like just buy it;d nvm of that i don't have a change stick with gt 640 with low fps and even more of the new games won't even run 😀 or get 770 thanks again;d!
4xMSAA is just GPU killer, you'll need 2x780 TI to handle ultra at 1080p with 4xMSAA (I'm not sure if I'm exagerating)...I have a GTX 770, I can play Crysis 3 on ultra 4xSMAA, the game looks absolutely gorgeous, and the game never drops below 30 FPS on "Welcome to the Jungle". My advice? Buy the GPU, it's a beast. for at least the next 3 years...or the next Crysis :)
What is your brand? I may get palit but if its a bad brand no.
PNY GTX 770. Actually it's a good card, silent and good cooling system. I have it since very few days so I can't say if it's reliable on long term. But I'm happy with it right now. Palits are good ones from what I heard.
I play crysis 3 to and I can run 4xMSAA with GTX-760 on ultra settings and my FPS won't go lowrer than 30FPS in "Welcome to the jungle", GPU killer is 4xSSAA which kills GPU's
4xSSAA (Super Sampling Anti-Aliasing) renders each frame at 4k and downsamples it to 1920x1080p.
Denis don't worry if you get GTX-770 you'll be able to max out almost every game :)
As I said many times to you Palit is really good brand which is highly underrated.
Asus DirectCU II has some problems in GTX-770 model same as Gigabyte Windfore, I know that MSI and EVGA's are also good. I heard about some problems on Asus and Gigabyte's GTX-770.
So the PNY 770 palit is a good deal?
Yes, some high end PNY cards comes with lifetime warranty :)
Hm that't the one that i will get but the other's are like that https://www.google.bg/search?q=PNY&es_sm=93&source=lnms&tbm=isch&sa=X&ei=lXp7U5OBOKXM0AWiwID4CA&ved=0CAgQ_AUoAQ&biw=1440&bih=799#q=PNY+770&tbm=isch&facrc=_&imgdii=_&imgrc=gYNiGIdIUqc3dM%253A%3Br9NqMoBiVY8RDM%3Bhttp%253A%252F%252Fcchotspot.com%252Fwp-content%252Fuploads%252F2013%252F09%252FPNY-Feature-470x260.jpg%3Bhttp%253A%252F%252Fcchotspot.com%252F2013%252F09%252F12%252Funboxing-the-pny-gtx-770-2gb-enthusiast-edition%252F%3B470%3B260 what is the difference?
So my gpu will be loud?
