Will i be able to max out all games 2012-2016?
Denis Stoikovski
2,200
So can i max out games like ac4 watch dogs crysis3 far cry 3 and far cry 4 ofc with i5 3350p palit 770 8 ram 1600mhz on 1440x900 res? also i will lower the shadows as much as i can but i want to keep the aa to a higher level.
Triple fan version won't be loud, I said only reference GPU with blower design fan would be loud.
Dont get pny. Having 1,2 or 3 fans doesnt matter, its how the hot air leaves the gpu and how strong the fans are. The highest rated brands are evga, asus, msi, and gigabyte. Evga is probably the most popular, then asus, msi, and gigabyte.
Well even if it was lound idk 😀 i just want good performance
Well yes 😀 as i see all of you aprove the card but my biggest oppression is will i have bottleneck with my i5 3350p its non overclockable cpu only turbo boost up to 3.3 will i have any probmels or it will be just perfect cause in gd the perf cpu for 770 is Core i5-4670K
It's a bit painful to explain you that 3350p is good CPU even for SLI of the top tier cards, I told you many times that 3350p is good CPU :)
Look in hierarchy chart for your CPU http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-5.html
It's on the top of the Intel gaming CPU's :)
Well i must be sure.. i had very bad exp with one pentium 😀( didn't know anything for a pc)
Okay many people are mistaking: do i meed the lastest cpu core i7-4770k to play games?
No. Lol. You can use a dual core i3 and have an excellent gpu and be able to ply all games. The gpu is like 85% of all the gaming, while cpu is less than 15%. Dont worry ur cpu is fine and its all abou the gpu.
Actually, newer games often tend to use more than 2 cores..So better have a quad core IMO.
the i5 3350p is quad
Yup. And it seems to be quite a beast.
Yeah! Intel's 2nd, 3rd and 4th gen. i5/i7 CPU's are great for gaming :)
get a good GeForce 770. get a better CPU, like 3570K. get 8GBs of DDR3 over 1600. you"ll be running everything @ 900p with 8xCSAA and all settings maxed. if you're worried about good graphics though 900p is very low. get a better monitor with @ least 1080p.
I have same ram and il get msi 770 to the cpu its close to the 3570k
I disagree with you, i5-3350p is good CPU and with i5-3570k he won't see any performance boost in games, my uncle plays BF3/4 with i3-3240 and GTX-650 pretty well on 1080p monitor so OP with i5-3350p and GTX-770 will max out almost all games :)
