[SOLVED] Will I be able to mount this 120mm PC case fan dust filter in the middle fan holes of this 360mm PC case fan?
SeriousGaming101
330
Hello all,
I am planning on buying this 360mm case fan:
https://www.amazon.com/Cooler-Maste...ld=1&keywords=360mm+fan&qid=1610450800&sr=8-2
However, I am planning on covering both sides of this 360mm PC case fan with individual 120mm dust filters on all 6 of the fan's sides:
https://www.ebay.com/itm/120mm-Comp...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
The problem is, I dont know whether I can install this 120mm dust filter in the middle fan because the holes in the middle fan looks like its bigger(maybe too big/wide) than the screw holes on the side of the 360mm case fan.
Do you think the dust filters' screws can be installed in the middle slot of the 360mm PC case fan without being loose/falling off?
If not, can someone find me a good 360mm case fan (NOT AIO) that has a similar size mounting screw holes for all it's holes for the 120mm dust filter to be compatible?
