Will I need 6 or 8 Compression Fittings?
SproutyPC
35
Hi guys I plan to watercool asap but my budget is constricted a little so if I can save £10 then it would help, I plan to buy this Res and pump combo:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-006-TL
Now I watched a Youtube video of a guy fitting the pump to the bottom of the res, the main thing I was trying to establish is will I need two Fittings on the pump AND the Res, or does the pump push/pull the res water through the holes on the res (the res has 3 holes and my guess is that I'd plug one and in/out the others) kind of like a bayres D5 would work?
Any help much appreciated
the only way to hook the res/pump to the radiator is with two fittings or with a threaded nipple. If your wanting to try mounting your res/pump to the radiator your setup should look like this....
pump/res -> radiator -> cpu -> gpu if your doing one -> back to the top of the res
If you need any help post up your computer build and ill help you find parts for the water loop.
