Good morning/afternoon all,
I started preloading BF4 last night after saying I wouldn't buy it...then I got concerned about my set up after reading the recommendations of a 3gb gpu. Here's what I'm running. I'm concerned about the gpu and the display as the display seemed to sway my settings on a couple current games.
27" 2560x1440 ips display
900w psu
AS Rock Z77 extreme4 mb
i5 3750 3.4 ghz quad core cpu
16gb ddr3 1600 ram
Nvidia 650ti boost 2gb gpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125457
WIll I be ok with the 650ti boost?
would a second card and do SLI for $150 be a solid option?
or is it really not worth it and and I'd be better to sell my current card and go bigger?
Thanks for any help/suggestions.
900w psu
16gb ddr3 1600 ram
