Will intel hd Ironlake graphics be able to run battlefield 3 on low settings
Computer LVR
72
Currently I am on vacation in Puerto Rico and I brought my laptop with me. And when EA had their summer sale I could not pass up the games they had for so cheap I got battlefield 3 for 5 dollars. Now I want to know before I download the game to my laptop (I have it but have not Downloaded it) if my laptop will be able to run the game at the lowest settings at 1366x768 at 30fps with intel hd ironlake iGPU. If not I will do 800x600 Now before I get yelled at, this is just to entertain myself while I am the plane to go back home, I have a recently built gaming rig back home that can run the game at max settings and that is why I bought the game
I checked the minimum system requirements for everything else and it looks to be good
PC Specs
AMD FX 6300 @ 3.8 Ghz
Asus M5A97 R2.0
G.Skill 8GB 2133 MT
XFX DD r9 270x Core clock 1180 Mhz Memory Clock 1500 Mhz
XFX Core Edition Pro 650W
Corsair Carbide 500R
WD Blue 1TB HDD
Laptop Specs
Intel i3 380M
Intel HD ironlake
3GB 1066MT
5400 RPM 500GB HDD
if this helps I will do the lowest resolution possible and play offline since you know I am on a plane
Origin was giving away bf3 for free for their on the house special which I believe ran for a couple of days.
But anyways, the i3-380m does not have hd 3000, it's simply called hd graphics and it's 3 tiers below the 3000. So you can imagine it's quite weak and the answer is no.
I updated my thread thanks, what about mass effect it seems to have lower system requirements, I dont know much about older graphics cards since I got in to pc building in the year 2010 but couldnt build one until I got a job last year. btw thanks k114 for the graphics info, never trust your mama to tell you your laptop specs, btw thanks techcdcl, I couldnt pass a 40 dollar discount for the case thoe so I went and got it, also I plan to keep the case as long as the front panel works and there is no rust
