Solution Rakanyshu Apr 8, 2017 Fudo__Barakudo : If it does,do I need to update BIOS? It is on the supported CPU list, http://www.gigabyte.com/Motherboard/GA-H110M-S2-DDR3-rev-10#support-cpu you just need to check it has the bios version F20a.
Ecky Illustrious Feb 3, 2013 7,592 2 38,960 Apr 8, 2017 #2 It will, if you use another CPU to update the BIOS first. Upvote 0 Downvote
Rakanyshu Distinguished Jan 10, 2015 432 26 19,140 Apr 8, 2017 Solution #3 Fudo__Barakudo : If it does,do I need to update BIOS? It is on the supported CPU list, http://www.gigabyte.com/Motherboard/GA-H110M-S2-DDR3-rev-10#support-cpu you just need to check it has the bios version F20a. Upvote 0 Downvote Solution
