What I would like to do: I need a case with great airflow to host the BeQuiet! Silent Loop 360 and the beefy Zotac GeForce RTX 2070 AMP Extreme Core.
I am wondering, if it will fit into the Silverstone RL06 Pro RL06 Pro ?
On the website it says: Support graphics card up to 13.7" (348mm) but I have no idea, if that is with front fans or not...
Let's suppose:
1. Length is given with fans
I see... So, if it's with front fans, we get a total usable space of: 370mm + 25mm (fan thickness) = 395mm
If now, I replace the front fans with the BeQuiet! Silent Loop 360, I have a usable GPU space of:
395mm - 30 (Radiator) - 25 (fans) = 350 mm
-> The Zotac GeForce RTX 2070 AMP Extreme Core has a length of 308mm --> So it fits
2. Length is given without fans
Usable Space: 370mm-25mm = 345mm
Usable GPU Space: 345mm - 55 = 290mm
-> The Zotac GeForce RTX 2070 AMP Extreme Core has a length of 308mm --> Does NOT fit
Hence, its really important to know...
I am also open to other case suggestions! I would love a front mesh, if possible.
Let's suppose:
