Z zomgdaboy Honorable Jun 29, 2013 30 0 10,530 Jul 12, 2013 #1 I reallyy wanted to buy thermaltake frio cpu cooler but can it fit my components! Intel i5 3570k Asus P8Z77-lk mobo
Solution envy14tpe Jul 12, 2013 zomgdaboy : My case is haf xm but i wanted to know if it will fit my LGA my mobo socket is 1155 I was in a store today and noticed the Frio OC box label does not include 1155, but the website does. Is this the one: http://www.thermaltake.com/products-model.aspx?id=C_00001600 It gets great reviews.
envy14tpe Champion Mar 3, 2012 9,581 14 56,665 Jul 12, 2013 #2 we need to know your case size...but more than likely..yes. CPU and mobo won't affect size of CPU...but case will. Upvote 0 Downvote
Z zomgdaboy Honorable Jun 29, 2013 30 0 10,530 Jul 12, 2013 #3 My case is haf xm but i wanted to know if it will fit my LGA my mobo socket is 1155 Upvote 0 Downvote
envy14tpe Champion Mar 3, 2012 9,581 14 56,665 Jul 12, 2013 Solution #4 zomgdaboy : My case is haf xm but i wanted to know if it will fit my LGA my mobo socket is 1155 I was in a store today and noticed the Frio OC box label does not include 1155, but the website does. Is this the one: http://www.thermaltake.com/products-model.aspx?id=C_00001600 It gets great reviews. Upvote 0 Downvote Solution
Z zomgdaboy Honorable Jun 29, 2013 30 0 10,530 Jul 12, 2013 #5 Yes it is the one. I guess it has 1155 but if it will only have 1156 thats ok because it is similar to 1155. Thank you very much! Upvote 0 Downvote
envy14tpe Champion Mar 3, 2012 9,581 14 56,665 Jul 12, 2013 #6 zomgdaboy : Yes it is the one. I guess it has 1155 but if it will only have 1156 thats ok because it is similar to 1155. Thank you very much! It's an awesome cooler. I wish I would have bought this instead of the CM Evo. Enjoy! Upvote 0 Downvote
