Will it fit?
Just a link to the case would have been easier...but
The case:
http://www.fractal-design.com/home/product/cases/core-series/core-3000-usb-30
Supports graphic card up to 270mm in length when all HDD cages are installed
Supports graphic card up to 420mm in length with upper HDD cage removed
The GPU:
Card Dimension(mm) 269 x 141 x 35
Bottom line - Yes, probably, just barely
Yes, it will fit. There is a chance that you will need to remove the HDD-Bay to make space.
From the Fractal Design website for your model case:
Supports graphic card lengths up to 270mm when removable HDD-Bay is in place
Supports graphic card lengths up to 420mm without removable HDD-Bay
The case:
The GPU:
I dont have the top bay in anyway, just 1 bay
Its the H7 Cryorig, as you can see the end of the CPU cooler sort of slopes down, which means it is nearly touching the GPU..
http://www.cryorig.com/h7.php
Ok, so its not a problem that it is sloping down and near enough touching the top of the GPU? because i was wondering i have the R9 270x now and if I get the 970 it'll be bigger right so it will touch the top of the CPU cooler?
Latest posts
