noxinum Distinguished Aug 7, 2016 135 3 18,685 Sep 29, 2016 #1 Will a H100I cooler fit in a Z170 pro gaming motherboard?
Solution Barty1884 Sep 29, 2016 A H100i will fit on any compatible socket motherboard, including an ASUS Z170 Pro Gaming (making the assumption that's the board you mean). Will it fit in your case, is another question all together - and will depend on the case you have.
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,353 108,740 Sep 29, 2016 Solution #2 A H100i will fit on any compatible socket motherboard, including an ASUS Z170 Pro Gaming (making the assumption that's the board you mean). Will it fit in your case, is another question all together - and will depend on the case you have. Upvote 0 Downvote Solution
noxinum Distinguished Aug 7, 2016 135 3 18,685 Sep 29, 2016 #3 I have a Fractal Design Define S which I think it will fit, was just worried about the motherboard and yes Z170 pro gaming not mini Upvote 0 Downvote
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,353 108,740 Sep 29, 2016 #4 Yes, it'll fit both the socket/motherboard & in your case Upvote 0 Downvote
