[SOLVED] Will it work and be future proof?
Am I correct in assuming that this is a desktop system (not a laptop)?
If so, then with 1080p at 60Hz, I would suggest upgrading to an RX 570 (US prices this gives best bang for the buck), or consider an RX 580 or a GTX 1650 Super.
The CPU is still fairly viable, being 4-core/8-thread. The 8GB of RAM may hold you back a little.
What brand and model of motherboard do you have? What exact brand and model of power supply are you using?
no this would be very hard to run any games at medium to high settings in most AAA games nowadays if you have a budget i could try to suggest some parts
