Will it work?
RossTheGuy
118
So I am planning on building a budget PC for gaming.
I am wondering is everything is going to work fine and should I worry about any parts:
CPU: Intel i5-4460
RAM: 8GB DDR3
GPU: RX 470 8GB Nitro+
PSU: XFX 550W
Motherboard: H81M-DG4
HDD: WD 1TB
Excellent build for 1080p gaming. Only comments, can you get a 120gb SSD? They are super cheap now. Also, you could upgrade CPU to i5-4590 and mobo to H97 if you can afford it. Those will increase build by around $75. If too much, pull the trigger on what you got.
Hmmm i will consider about the SSD.
You suggesting that I put my Windows 10 there so it boots up quickly?
And will the i5-4590 make any difference in gaming/FPS?
So in conclusion I can play games on my 1080p monitor at high-ultra settings?
The build you listed will play 1080p at Ultra. The 470 is a very good GPU and that i5 is good. Will the 4590 help in games...not sure..doubtful you'd notice, but I'd rather have a CPU hit 3.7GHz (4590) then only 3.4Ghz (4460). Where you buying?
I am buying in local hardware store in Croatia called Links.
